Jet Central Rabbit VT90
TX
Jet Central Rabbit VT90 REDUCED
Up for sale is my Jet Central Rabbit VT90 with 19lbs thrust, propane start. I'm the second owner, the first owner bought it new and put 5 hours on it. I put another 4.5 hours on it so the turbine has 9.5 hours or 575 minutes on the clock. The ONLY reason I'm selling it is to free up some funds for a new jet for my Behotec 220 sitting on the shelf. Otherwise I'd keep it, it's been a great reliable turbine for me. Starts and runs perfect and looks basically new. Being propane start, it's the fastest starting turbine I've had. Gets to idle rpm in probably 20 secs on startup. Comes with everything pictured and in the original Jet Central case with instruction manual. $1600 shipped in the USA. (Reduced!) $1500 shipped! You can check my trader rating on RCgroups under same screen name for assurance. Ask if you have any questions, thanks!
