Mockingbird Aviation Tailwheel Soring Set!
My Feedback: (102)
TX
Mockingbird Aviation Tailwheel Spring Set!
Mockingbird Aviation would like to announce the release of a new product for your consideration.
It's an aluminum tailwheel spring setup that houses a stainless steel 4-40 threaded rod and stainless steel compression spring. The aluminum
housing has been clear anodized for appearance and longevity.
There are many excellent tailwheel spring options on the market and a couple tailwheel spring options that work, but don't look quite as good as their bling tailwheel counterpart.
This tailwheel spring setup was designed to fit 33%-45% aircraft but will connect to any size airplane that allows enough room between the rudder tiller arm and the tailwheel tiller arm. As designed, you'll need a minimum of 4.25 of clear space between the two connecting points. If you cut off .5 of the 4-40 threaded rod, then this system would operate in 3.75 of clear space.
Included with the purchase:
2- tailwheel spring housing and cap assemblies. (Already assemblies with rod and spring inside)
2- Dubro HD 4-40 ball link connectors with connecting hardware
2- 8 inch pieces of plastic coated cable
4- crimps for attaching cables
1- Mockingbird Aviation decal
1- set of instructions
*** Price for each set is $35.00 plus shipping ***.
Shipping is $4.00 USPS ground or $7.00 USPS priority. Standard International shipping is available at $15.00. Payment can be made via PayPal and I'll only ship to confirmed addresses.
PayPal address: [email protected]
Craig Rideout
325-665-4452.
Craig Rideout
325-665-4452.
