Skymaster 1/5 F16
Skymaster 1/5 F16
Hey guys I'm just throwing this out there to see if there is any interest in this beaut of a plane.
I have a huge list below of the parts and pieces that went into this plane with costs. All prices have been converted to Canadian dollars using my invoices and exchange rates at the time of purchase. all invoices are available upon request if someone is to buy it.
I have currently 7 very successful flights on this last year and this year and flew absolutely amazing. The kingtech 310 is an amazing turbine and pushes this around the sky very fast with great vertical climb.
The K310 is 007 off the assembly line.
Plane was ordered with just about every option available.
-Scale Landing gear
-Factory installed gear doors
-Kevlar Fuel tanks
-Hardware Kit
-Cylinder set for gear doors
-Long wingtip missiles
-Wing Bag
-Scale Nozzle
-Air Kit
-Dual Wall exhaust pipe
-Carbon Fiber Bypass
-Speed brake kit installed
-Operating Canopy installed
-Smoke tanks
-Light set, navigation, strobe and main landing gear
-Afterburner Light ring
-Light set for nose gear
-Factory light set intalation
-Scale cockpit
Some of the pictures attached of the inside are during construction and was not complete such as not all wires being tied down and neatly placed. This is all completed now and very neat and tidy through out the entire plane.
Also noted some of the pictures I took were a bit blurry but for the most part pretty good.
Airframe deposit $3115.84
Airframe balance $7131.07
Shipping airframe $890.00
Shipping dreamworks $92.86
Duties on airframe only $512.35
Turbine K310 with 9.9v 3800mah battery $5321.39
Kingtech turbine telemetry $94.18
x6 Savox 1230SG Monster torque servos $565.02
x2 JR NX8931 $403.62
Kingtech LCD mount $26.91
JR 3 axis gyro $295.99
X2 Hyperion 6.6v 3800mah LiFe batteries $166.71
LiFe Source 6.6v 1800mah $56.99
JR Pitot air speed $80.71
JR Altimeter $94.17
JR Telemetry Adapter $34.76
JR Diversity remote $71.30
JR RG812BX receiver $134.53
x5 XBus HD servo converter $302.66
XBus HD Center hub $161.44
Electric canopy actuator $94.18
X4 Jet-Tronics double valve $618.92
Power box smoke pump $227.39
X2 Robart air tanks $42.98
Xicoy Air sequencer w/ failsafe $100.91
12" jet pilot with servo operated head $201.82
Interairco high flow super trap $125.80
Interairco mini trap fuel filter high flow $103.27
Interairco horizontal mount $31.62
Wing tip missiles $127.82
Stainless steel smoke tube $20.18
Overflow kit add on $26.90
X2 Startup overflow vent system high flow $80.70
X3 Jet tech big bore high flow fuel fitting $113.02
X2 Seacraft V2 servo arms $24.49
X12 Festo 6mm tubing $22.60
Simulated carbon fiber $21.46
X4 Festo 6mm barbed T $22.60
X4 Ball mount Valve red $80.46
X4 Festo Ball valve 6mm $79.38
X2 air gauge $48.37
Brake line $3.70
X4 Festo 6mm tubing mount $23.41
X2 Festo 6mm Caps $10.49
X4 dubro 10oz smoke tanks $31.96 can
X2 Robart 5/8 air cylinder $83.98
X2 Hangar 9 2" servo arms $25.98 can
X6 Robart air line $77.94
X2 Robart quick airline disconnects $35.98
X4 Parsons Servo safety clips $47.12
X2 48" Servo extensions $16.98
X3 36" Servo extensions $17.97
X4 24" Servo extensions $23.96
X5 18" Servo extensions $29.95
X3 12" servo extensions $14.97
X4 6" servo extensions $19.96
X2 3" servo extensions $8.98
Male to male 6" $5.99
Male to male 12" $5.99
Male to male 18" $5.99
X2 Hyperion Balance cable extensions $9.98
X3 wire Tidy Strips $8.03
X3 tubing tidy strips $8.03
JR Switch $9.99
X3 Female Deans 4 packs $23.97
X4 Male Deans 2 packs $22.36
Total $22,324.80
Tax on everything but airframe, duties and shipping +$529.13
Grand Total $22,853.93
Asking $18000 RTF Canadian
$13,500 USD
I have a youtube video of gear swings and a walk around on rccanada but cant seem to post them on here. just search my name of this jet there for the videos. any issues PM and I can send the link as well.
-Scale Landing gear
-Kevlar Fuel tanks
-Hardware Kit
-Wing Bag
-Scale Nozzle
-Air Kit
-Smoke tanks
-Scale cockpit
JR Altimeter $94.17
X2 air gauge $48.37
Brake line $3.70
JR Switch $9.99
Total $22,324.80
$13,500 USD
-Scale Landing gear
-Kevlar Fuel tanks
-Hardware Kit
-Wing Bag
-Scale Nozzle
-Air Kit
-Smoke tanks
-Scale cockpit
JR Altimeter $94.17
X2 air gauge $48.37
Brake line $3.70
JR Switch $9.99
Total $22,324.80
$13,500 USD
-Scale Landing gear
-Kevlar Fuel tanks
-Hardware Kit
-Wing Bag
-Scale Nozzle
-Air Kit
-Smoke tanks
-Scale cockpit
JR Altimeter $94.17
X2 air gauge $48.37
Brake line $3.70
JR Switch $9.99
Total $22,324.80
$13,500 USD
