HSD F-16 Turbine RTF
My Feedback: (48)
Excellent condition HSD F-16 turbine. Only has 7 flights. No crashes or even hard landings. This jet flies easy and predictable. Strong hydraulic landing gear. Several modifications done. Reinforced the elevators with aluminum and epoxy filling up the hollow portion and drilled through elevator for the hex screw. The elevators is now solid and will not collapse like others out there. Also upgraded elevators and ailerons servo to Hitec digital. I also added spring loaded inlet doors for more air intake that can boost the thrust and start the turbine with hatch attached, this avoid starving the turbine with inhtake air. Lastly, I changed the original anti-bubble tank into BVM UAT. This come complete with ACE60 turbine minus RX and batteries. Turbine serial # 146 with 4hrs 38 min. with FOD screen.Paypal - add 3.5%. Money order/cashiers check/personal check (need to clear prior to shipment). Local pickup preferred, but will ship at buyer expense. I still have the box, so shipping can be arranged. I only ship using UPS. Shipping to CONUS only.
