Atj 190 sv turbine
My Feedback: (21)
FL
Atj 190 sv turbine
ATJ 190 SV Turbine:
Used only for two flights has 156mins since new no crash history or damage!
ATJ190SV Turbine engine Specifications
Dimensions : Outer Diameter 112mm; Length: 298mm
Weight : 1780grams (including starter)
Maximum thrust : 18.8KG @ 123,000rpm(41.1)
Idle RPM : 35,000 Idle
thrust @ 35,000 : 0.75KG
EGT : 550 - 690 degree C
Fuel Consumption : @ max rpm 580 gms/min
Fuel/ oil : Jet fuel or Kerosene or Diesel + 5% oil (synthetic turbine engine oil)
ATJ190SV Engine package include
1. Turbine engine
2. Engine Mount set
3. Fuel pump set( BRAND NEW)
4. ECU ( Xicoy V10 Kerostart )
5. GSU (Xicoy GSU for V10 ECU )
6. Electronic cables
7. User Manual
8. Ecu 5000 7.4 battery
* New fuel pump is provided due to the old fuel pump being faulty. As a result total mins does not reflect total flights due to many starts to diagnose the issue.
Asking $2200 shipped if using PayPal please apply 3%.
1. Turbine engine
2. Engine Mount set
7. User Manual
