HSD F-16 turbine Jet
My Feedback: (48)
Good condition HSD F-16 turbine. Only has 7 flights. No crashes, just minor scratch at exhaust nozzle during high alpha. This jet flies easy and predictable. Strong hydraulic landing gear. Several modifications done. Reinforced the elevators with aluminum and epoxy filling up the hollow portion and drilled through elevator for the hex screw. The elevators is now solid and will not collapse like others out there. Also upgraded elevators and ailerons servo to Hitec digital. I also added spring loaded inlet doors for more air intake that can boost the thrust and start the turbine with hatch attached, this avoid starving the turbine with inhtake air. Lastly, I changed the original anti-bubble tank into BVM UAT. This is ARF, turbine is not included. Paypal - add 3.5%. Money order/cashiers check/personal check (need to clear prior to shipment). I still have the box, so shipping can be arranged, I will have to un-glued the bottom fins so it can fit back into the original box, you just have to glue those back. Free Shipping to CONUS only.
