Spitfire Mk.IX 81" Rc Warbird Full Composite by TopRC Model
My Feedback: (8)
Full composite construction , sandwichrumpf by Airex, balsa & epoxy.
All surface prepainted,decals applied and clear coated
Scale cockpit, scale exhaust included.
Detachable Scale gun set and antenna included;
Detachable main wing and tailplane for easy transportation;
Removable hatch on fuselage for easy access into the plane and change accessories;
Functional flaps for smooth landing.
High quality CNC Alum. push rod included
More than 95% assembled complete in factory.
Can be powered by engine or motor.
12mm corrugated board boxes packing to protect the parts to avoid damaged.
SPECS:
Specification:
Wing Span: 2058mm/81in
Length: 1715mm/67.5in
Flying Weight: 7.6kg
Wing area: 74.95 dm2
Engine: 35cc
This Package includes
TopRCModel Spitfire Mk.IX Electric Retract Set
TopRCModel 3 bladed Spitfire Spinner
Biela 3 Bladed 19x10 Carbon Propeller
All items listed above including aircraft are new and has never been used,
please contact me if you need more info on this thank you.
SPECS:
Specification:
Engine: 35cc
