3w150 in-line twin
3w150 in-line twin
Engine has been crashed and repaired
crank case welded
front out put shaft on crank replaced
front intake reed cage hs some damage does not leak
hss been run for close to an hour on test bench
runs good temps in mid 180 on both cylinder
if intrested can send video of it running
7012125788 please call if you have questions
crank case welded
My Feedback: (138)
crank case welded
crank case welded
