Team Associated RC10B4
This Team Associated RC10B4 roller started out as a #9034 kit, and is being sold to make room for my next RC purchase. The buggy has seen its share of track time so all the normal nicks and scrapes are to be expected. Although you can't see the rear axle drive pins/wheel spacers/shims behind the wheels, what you see in the pictures is what you get. This RC10B4 is a non-hex two wheel drive drive buggy with front axles that uses wheels with bearings. Spur gear is worn a bit, but is still usable. A couple of pictures show the long set screws for securing the battery strap with thumb screws...they are not included. Instead, the original 4-40 SH screws w/holes in them were put back into chassis for securing the battery strap with body clips. You will need to add your own speed control; motor, servo, receiver, and battery to get the RC up and running.
Some things to note on buggy:
Item Return is not accepted as this RC is being sold as-is.
Buyer Pays Shipping.
Any questions, please ask.
- Diff/tranny has been cleaned and rebuilt.
- Shocks cleaned and rebuilt with new o-rings.
- Lunsford turnbuckles
- RPM ball cups
- CVD rear axles
- 69T Spur gear
- Hard anodized shock bodies
- Lunsford turnbuckle wrench included
- Manual is included
- Wing mount has crack
- New wing has been mounted
- Spare tools/servo horns/anti-squat shim/rear toe blocks from kit are included
- Bearings oiled and are in working condition
