Extra 260 180 SEA-56
My Feedback: (27)
TX
If you always wanted to have a great sized gas plane that is very sturdy and easy to fly this is the plane.
I bought this plane several years ago and took my time to make some modifications that will strengthen the cowl.
The only thing what will be needed to be done is to replace or repair the top rear top of the canopy. The pilot will need to be reattached
inside canopy.
This plane has never been flown! I accidently dropped canopy on floor while moving.
LOCAL PICK UP ONLY! Austin, TX area of Location.
Spec:
inside canopy.
Spec:
- Engine Size: 1.60 2-stroke; 1.80 4-stroke (Mounted MLD 25 cc Gas, brand New!)
- Experience Level: Advanced
- Flying Weight: 12.8-13 lb (4.8-5.8 kg)
- Fuel Type: Gas
- Overall Length: 64 in (163.5 cm)
- Plane Type: Aerobatic & 3D
- Power Plant Size: MLD 28cc Gas (currently installed with dual pipe exhaust)
- Radio: 6 channels
- Servos: 6 digital New Hi-tech servos installed
- Spinner Size: 3.5 inch (included)
- Trim Scheme Colors: UltraCote White (U870) True Red (U866) Midnight Blue (U885)
- Wing Area: 967 sq in (62.4 sq dm)
- Wingspan: 70.9 in (182 cm)
