Rage Super Cub MX Micro EP 3-Channel RTF Airplane
My Feedback: (850)
MO
BRAND NEW IN THE BOXThe Super Cub MX is not only a great way to build RC piloting skills, but also a fun airplane for experienced RC enthusiasts to fly in compact areas. It's manufactured from durable, repairable EPP foam with carbon-fiber wing struts and tail reinforcements to help survive rough landings; while the lightweight construction and large capacity battery deliver flight times of up to 8 minutes. The model features a pre-applied, attractive trim scheme with everything needed to start flying in the box; including a 2.4GHz standard size 4-channel transmitter, a pre-installed airborne electronics system, a convenient USB charger, and a powerful 3.7V 360mAh LiPo battery for extended flying time. The only additional items required are four AA batteries for the transmitter and you will be flying maneuvers around your local park within minutes of opening the box.
Key Features:
Made from durable and easy-to-repair EPP foam
500mm wingspan allows for easy transportation
Lightweight construction provides for flight times of up to 8 minutes
2.4GHz Airborne Control System with integrated 1.3-gram servos, receiver, and ESC
Coreless motor with gearbox delivers outstanding thrust
Includes 1S 3.7v 360mAh Lipo battery for extra-long flight times
PASS (Pilot Assist Stability Software) system provides confidence as flying skills progress
With PASS, a simple transmitter-mounted switch allows pilots to easily choose from three levels of system engagement - Full Assist, Partial Assist, and No Assist.
Specifications:
Wingspan: 19 3/4" (500mm)
Length: 13 15/16" (355mm)
Weight with Batt: 1.9 oz. (54g)
Battery: 1S 3.7v 360mAh Lipo
Transmitter: 4-channel 2.4GHz
Controls: Throttle, rudder, elevator
On-Board-Electronics: Combination RX/ESC with integrated 1.3-gram servos
Items required for completion: 4 AA batteries for transmitter
CALL text or email 314-256-9987 or [email protected]
