Evo Jet 170s
Evo Jet 170s
New in the box and unused 5 Evo Jet 170s with 50 hrs between inspections and 2 year warranty from defects. 2350.00 each Shipped to your door step.
EVO jet 160 Booster
I have a EVO jet 160 that i have problem with and I think is the ECU do you happen to have any parts for my 160 that you may want to sale or do you repair them please let me know Thanks RAY (818)620-3691
My Feedback: (54)
Ray, I have had a 160 since 2009. If you move the engine from one jet to another, do a reset of the ecu for it to go through a new calibration of the fuel system draw for pump voltages. I've done that and it helps the issues. Also replace the Ethernet cable. You can get them for as low as a couple dollars. Check the battery connections for corrosion, or maybe the switch is bad?
EVO jet 170 new
I will take one of your EVOjet 170 for $2350.00 dollars shipped to me in California please call me so we can do the deal over the phone with my credit card Thanks RAY (818)620-3691
EVO jet 170 new
I like to make an offer for your turbine 170 evo new if it comes with fuel line and GSU and Manuel starter fuel valve and warranty for $2350 dollars shipped to me in CA. 91604 Thanks RAY
