RotoMotor 35Vi
My Feedback: (57)
MO
RotoMotor 35Vi
DISPLACEMENT 34.8 cc
BORE 39.5 mm
WEIGHT 1480 g / 3.26lb
PISTON ROD 2 x NEEDLE BEARING TORRINGTON
CRANK SHAFT 2x BALL BEARING
IGNITION PROCESSOR CONTROLLED
Fuel/Oil 32:1 break in, 50:1
Factory Warranty 24 Months
New gas engine especially designed for planes, really well constructed and very friendly to use.The Roto motor is very high quality enginering product.We have a large shipment of Roto motor engines in stock now -distributor direct pricing means you save money! Roto Motor for sale:
I HAVE ALSO IN STOCK:*
Rotomotor 70V2
Rotomotor 50V2
Rotomotor 35fs
Rotomotor 85fs-ng
BORE 39.5 mm
Rotomotor 70V2
Rotomotor 50V2
Rotomotor 35fs
Rotomotor 85fs-ng
My Feedback: (57)
MO
Hi jtp
Power figures? 1300-8000 rpm with prop 19x10 20x10 21x8 broken propeller 18x10 Static engine thrust is 14kg approx 30.9 lbs.
tnx.shosho
tnx.shosho
