FPV Plane 1900mm ARF
Description:Brand Name: MyFlyDream (MFD):https://www.aliexpress.com/store/pro...1fac73a8giymhc
Item Name: Nimbus
Wingspan: 1800mm
Length: 1300mm
Servo: 17g*2 + 9g*2
Max. Flying Height: 3500m
Max. Flying Speed: 140km/h
Max. Take-off Weight: 5.5kg
Max. Payload: 1.5kg
Max. Endurance: 1.5-2.5h
SD Image Transmission Effective Range: >10km
Features:
Quick disassembly design,extremely convenient to disassemble and carry.
The wing and the head cover are connected by double hook forms,very convenient to use.
Corresponding solder joints and pins for the motor,servo and ESC has been designed inside the fuselage.
The carbon tube has been extended to three quarters of the wing,great wing strength.
With PCB,the pin of the camera and the airspeed have been connected,just need to simply plug the cable.
All interfaces for flight controller channels and expansion modules are reserved.
Battery compartment can hold max 6S 16000mAh lipo battery,long flight endurance.
Almost Ready to Fly version:
Package Included:
All parts of Nimbus FPV plane
Servo * 4
2815 Motor Motor * 2
HobbyWing 30A ESC * 2
9075 prop * 2
12V+5V power supply and 100A MFD CurrentSensor onboard
The plane has been assembled in the factory.
It's Almost Ready to Fly.
MFD Autopilot can be installed on this plane in seconds.
Specifications:
WingSpan: 1800mm
Length: 1300mm
All Up Weight: 3500~5000g
Endurance: 120Min
Battery: 6S 10000~12000mah LIPO (Not included)
Item Name: Nimbus
Wingspan: 1800mm
Length: 1300mm
Servo: 17g*2 + 9g*2
Max. Payload: 1.5kg
Features:
Package Included:
Servo * 4
9075 prop * 2
Specifications:
WingSpan: 1800mm
Length: 1300mm
Endurance: 120Min
