Go Back  RCU Forums > Marketplace
Reload this Page >
Dynam F6F Hellcat...
Old 05-18-2019, 12:00 PM
nonefor2
Default Dynam F6F Hellcat...
Dynam F6Hellcat ..extra 2 servos if you choose to add flaps...new 80amp esc as an extra also if needed...comes with installed retracts. Buyer pays shipping....
Dynam RC Airplane Warbirds F6F Hellcat 1270mm Wingspan - PNP
The Grumman F6F Hellcat was a World War II carrier-based fighter aircraft. Dynam is proud to bring you a scale EPO foam recreation of the F6F Hellcat. It features a high performance 500KV brushless motor and 40A brushless electronic speed controller. It also comes equipped with a totally redesigned electrical retract system allowing the pilot to tuck the landing system out of the way and reduce drag.
The Dynam F6F Hellcat comes with the essential electronics installed. The motor, ESC, servos and most linkages are pre-installed from the factory. This will save plenty of time in installing.
What are included:
Dynam F6F airplane, motor, ESC, 4*9g servos
What are required:
6-Channel or above transmitter
6-Channel receiver
14.8V 2200mAh Li-Po, 25C battery and charger
1 hour assembly time
Specifications:
Material: EPO Foam
Wing Span: 1270mm (50in)
Flying Weight: 1600g
Wing Loading: 53g/dm˛
Fuselage Length: 1054mm(41in)
Center of Gravity: 70-75mm from the leading edge of the wing at the root
Motor: Detrum BM3720A-KV500
ESC: 40A Brushless
Propeller: 3-Blade Scale Prop
Servo: 4x 9g
Elevator: Yes
Rudder: Yes
Ailerons: Yes
Flaps: Yes
Landing Gear: E retract
nonefor2 is offline
