F-22 Yellow Aircraft
My Feedback: (24)
TX
For sale is a Yellow Aircraft F-22, the all composite version, not the pre-built one. The aircraft is completely built and painted, flight tested in Waco on 6/15/19. Included is a new KT 160 with turbine support equipment. The engine has less than 30 minutes run time and is a perfect match for the F-22. Also included is a 20 channel Spektrum receiver and the plug-in Gyro. All servos are high end Spektrum. The airplane is completely built, has a full cockpit, includes 2 LiFe 6.6 volt batteries and 1 9.9 LiFe volt battery for the turbine.
Extensive detail work at the exhaust outlet includes titanium shields to dissipate the heat.
Overall length is 7 feet. Haven't weighed it but believe it to be about 32 lbs. Includes retract unit and proportional brake unit.
Too big to ship without extensive disassembly so local pickup preferred.
$5,000 cash or PP but no PP fees.
