Top Flite G.S. P-51 ARF, New, Never Completed, Robart Pneumatic Retracts
New Top Flite G.S. P-51 Mustang ARF, Never Finished. Robart Pneumatic Retracts w/ Struts, Fixed Tail Gear installed. Dave Brown 5" Alum Spinner (factory spinner was poor quality), Dubro 5" Tires, 2 Canopies, one NIP. Everything is new. Needs only control horns and clevises to complete!
Assembly manual will be emailed to buyer.
$679.00, with local Pick up in San Diego.
SPECIFICATIONS
Engine: 2.1 -2.8 cu in (34.5 - 46cc) 2-stroke
OR 2.5 -4.3 cu in (41-70 cc) spark ignition gasoline engine
Wingspan: 84.5" (2146mm)
Wing Area: 1245 sq in (80.3 sq dm)
Weight: 19 - 24 lbs (8.61 - 10.88kg)
Wing Loading: 32 - 35 oz/sq ft (98 - 107 g/sq dm)
Length: 73.5" (1865mm)
Airfoil: Fully-symmetrical, low-wing
Center of Gravity: 4-9/16" (116mm) Back from the wing's leading edge
Control Throws: High Rate Low Rate
Elevator: Up & Down 9/16" (14mm) 3/8" (10mm)
Rudder: Right to Left 1½" (38mm) 1" (25mm)
Ailerons: Up & Down ¾" (19mm)up ½" (13mm)up
5/8" (16mm)down 3/8" (10mm)down
Flaps: 1-3/16" (30mm) 2-1/8" (55mm)
SPECIFICATIONS
