RCGF 20cc RE Stinger Rear exhaust
My Feedback: (850)
MO
RCGF 20cc RE Stinger Rear exhaust NEW in box Authentic true McCoy (see note below)
Call text or email 314-256-9987 or [email protected] pay-pal ready or credit card over the phone.
PLEASE NOTE: Please be cautious when purchasing RCGF engines elsewhere, other than RCGF USA or IBCINYOURC imposters/clones are out there claiming to be & saying they are RCGF or adding their company name onto RCGF brand SAYING RCGF contacted them to be their distributor it's an outright LIE. nor did any merge take place also a LIE these engines ARE fake counterfeit clones.
RCGF 20cc RE
Glow size;gasoline economy & ease!
Glow power isn't the only option anymore. The RCGF20CC RE not only fills the displacement gap, but includes a beam mount to make the glow-to gasoline upgrade drop-in fast and easy. A rear pumper carb simplifies installation and adjustment.RCGF 20cc RE is starting ease and top performance make the 20CC RE an attractive alternative to glow and a solid buy for value and performance.
RCGF 20cc RE
Parameter:
Type : 2 cycle piston valve type gasoline engine for airplane
Piston displacement Cylinder (cc) : 20cc (1.22 cu in)
Bore x Stroke (mm): 1.3 in(32mm) x 9.5 in (24mm)
Carburetor : Walbro
Ignition : DC-CDI (Computer Controlled auto advance, electronic ignition system)
Power supply: 4.8-8.4V
Maximum Output :2.8HP /2.1KW
Requires: Gasoline, 2-cycle oil, ignition battery & propeller
speed rang : 1500-10500rpm
Gasoline-Version : Pre-mixed Fuel, 25-40 (Gasoline):1 , Recommend1
(90% high otcane unleaded gasoline, Import gas into carbon fiber installations valves)
Lubrication Oil : 2 cycle engine oil
Propeller : 16X6 8900;16X8 7900rpm (Standard Two leafs prop)
Suggested Propellers: 14x10, 15x8, 16x6, 16x8, 17x6
Sparking plug: NGK CM6 Type
Cooling System : Air Cooled
RCGF engine package Includes: electronic CDI ignition, muffler, spark plug, gaskets, bolts, throttle arm extension & manual.
Weight :
Engine: 1.37 lb (620 g)
1XMuffler: 2.08 oz (59 g)
Ignition Module: 4.4 oz (125 g)
Total: Weight: 1.75 lb (795 g)
Technical Data:
Ignition Battery: 4.8-8.4 NiCd or NiMH, 6.6V LiFe or 2S LiPo pack
Gasoline/Oil Mix: 30:1
Replacement Spark Plug: NGK CM6 or equivalent
Idle Speed: 1800 rpm/min
Static Thrust:
14.2 lb (6.4kg) @ 328 ft (100 m) altitude
12.8 lb (5.8kg) @ 5,900 ft (1800 m) altitude
RCGF 20cc RE
RCGF 20cc RE
Parameter:
Carburetor : Walbro
Weight :
Technical Data:
Static Thrust:
