Top Flite ZERO 86"
My Feedback: (23)
Top Flite ZERO 86"
This is a used about 4 flights only with no hard landings or any damages or any problem ARF Top Flite 86" wing span ZERO . the engine is RCGF RE 60cc gasoline engine . engine was brand new too when i put it on. it has lots of power and very smooth running . comes with all JX servos metal gear digital and high torque 6221MG / 287OZ /// Robart air retracts main and tail /// robart air kit /// original two blade aluminum spinner /// 3blade aluminum spinner witch i purchased separate and never been used /// 4.5" special tiers with aluminum rims /// 3000MAh life battery for receiver /// 2200Mah life battery for electric ignition /// aluminum twin heavy duty on/off switch with fueling dot and charging jack /// brand new clear 34" gas tank . so every thing was brand new when i build it . the futaba receiver is not included in this sale . thanks for watching and if you have any questions please ask before buying. pick up only
