Fei bao swordfish rtf
This custom painted Fei Bao Swordfish is RTF. Comes with an ATJ 220SV Turbine. Savox servos throughout the jet. Has 2 perfect test flights.
Length: 3100MM Wingspan: 2560MM
ATJ TURBINE
Xicoy V10 kerostart ECU and GSU easy to use .
ATJ220SV Turbine engine Specifications
Dimensions : Outer Diameter 112mm; Length: 293mm
Weight : 1780grams (including starter)
Maximum thrust : 22KG @ 123,000rpm
Idle RPM : 35,000 Idle thrust @ 35,000 : 0.85KG
EGT : 430 - 630 degree C ,
Fuel Consumption : @ max rpm 650 gms/min ,
Fuel/ oil : Jet fuel or Kerosene or Diesel + 5% oil (synthetic turbine engine oil)
This jet is in perfect condition. Its a very big jet. Shipping would be almost impossible. So local pick up or setup a meeting place in Florida.
Any questions please feel free to ask.
ATJ TURBINE
