HSD T-33 120mm EDF jet
My Feedback: (320)
NIB HSD Jets 120mm EDF T-33 in the Yellow Ribbon Scheme.
I opened the box, inspected the components to ensure there was no damage during transit.
Very nice airplane! This is a big EDF jet and from the videos looks like it flies great.
Comes with 2 jet USA 7.4V, 2700mah RX packs with XT-60 connector
Here is the link to the description and specs.
https://hsdjetsusa.com/hsdjets-s-edf...colors-pnp-12s
Free shipping via Greyhound
$1200.00
Gary 602 885-7703
$1200.00
Gary 602 885-7703
My Feedback: (320)
Ken,
Here are the specs of the HSD T-33 EDF jet, as it comes direct from the manufacture.
You can also go to: www.HSDJETUSA.COM to get complete detials, pictures and details.
Gary 602 885-7703SPECIFICATIONS:
Wingspan 2018 mm (79.4 in) Length 1800 mm (70.9 in) Flying Weight 7.5kg (16.5 lb) Cruising speed 150~180 km/h Flying time 3~5 mins Wing area 56.5 dm2 Wing load 132.8 g/dm2 Main material 35 times EPO Painting surface Matte environmental water-borne paint + decal Suitable experience level □Zero basis □Beginner ■Intermediate □Advanced PNP Assembly difficulty □☆10mins ■★☆30mins □★★60mins Suitable for ambient temperature 0℃~40℃ Radio System 7 channel (required & not included) Control System MFC-2085 Power System 120mm S-EDFwith Hobbywing 5268 Inner rotor motor ESC Hobbywing 160A Servos7.4V 25g×2 Metal gear with 480mm lead (left & right ailerons forward)
7.4V 25g×2 Metal gear with 230mm lead (Flap×2 forward)
7.4V 25g×3 Metal gear with 80mm lead (elevator×2 & rudder×1 forward)
7.4V 12g×1 Metal gear with 380mm lead with protection function (Nose wheel steering forward)
7.4V 12g×1 Metal gear with 320mm lead with protection function (Front wheel cover plate forward)
7.4V 12g×2 Metal gear with 80mm lead with protection function (Rear wheel cover plate forward)
Recommended Power Battery 6S,22.2V,5200mAh,45C×2,LiPo with AS150 type plug(required & not included) Recommended Receiver Battery 2S,7.4V,2200~32000mAh×2,LiPo with XT60 type plug(required & not included) Ailerons Yes Flaps Yes Elevator(Horizontal tail) Yes Rudder(Vertical tail) Yes LED lights system Yes Electromagnetic brake system Yes Reinforced gyro Selective configuration (not included) Packaging / Size Packing Box + Outer Box(Card mark)/52.56×21.3×16.9(inch) CG (Center of Gravity) 180mm from the leading edge of the Main Wing Landing Gears Metal electric retractable hydraulic landing gear×3 Battery Charger LiPo battery charger (required & not included)
PACKAGE INCLUDES:
REQUIRES:
PACKAGE INCLUDES:
- Fuselage×1 pcs
- Left main wing×1 pcs
- Right main wing×1 pcs
- Left Horizontal tail ×1 pcs
- Right Horizontal tail×1 pcs
- Vertical tail×1 pcs
- Nose×1 pcs
- Cockpit×1 pcs
- Left auxiliary tank×1 pcs
- Right auxiliary tank×1 pcs
- 1# Main wing carbon tube L=820mm external diameter 16mm×1 pcs
- 2# Main wing carbon tube L=760mm external diameter 10mm×1 pcs
- Horizontal Stabilizer carbon tube L=650mm external diameter 6mm×1 pcs
- Accessories Bag 1 ×1 pcs
- Screw (HM3×10mm)×8 pcs (Horizontal tail)
- Screw (HA3×10mm)×8 pcs (Vertical tail / Tail nozzle)
- Screw (HA3×14mm)×8 pcs (Power)
- Screw (HM3×14mm)×8 pcs (Wing)
- Screw (HM4×25mm)×8 pcs (Auxiliary tank)
- Screw (PWM6×70mm)×6 pcs (Nose)
- Accessories Bag 2 ×1 pcs
- 100mm signal line(JR male+JR male) ×8 pcs
- Manual×1 pcs
REQUIRES:
- 7 channel radio system(radio & receiver) (required & not included)
- 6S,22.2V,5200mAh,45C×2,LiPo with AS150 type plug (required & not included)
- 2S,7.4V,2200~3200mAh×2,LiPo with XT60 type plug (required & not included)
- LiPo battery charger (required & not included)
My Feedback: (20)
NC
Thanks for the reply and inventory,
I assume since there is no mention of Motor, Fan or ESC they are not included with the kit and will need to be purchased? I see wheels but what about retracts? Thanks
Ken
Ken
