ROXXY BL Control 975-12 Regler ESC For helicopter - Air / Heli / Boot / Car
FL
Robbe 8639-Roxxy BL-Control 900 Series Brushless Regulator 975-12 Opto 75A 4-12S (New)
Note:This was never used. I just installed the plug and programmed it for 6s But you can set up at your convenience. The manual is clear and simple.
PayPal or Money Order: Handling and Shipping $6.00
If you pay by PayPal include fee , please...
Programming options:
o Model type: Air / Heli, Boot / Car
o Battery type: Lipo, NiCd / NiMh
o Direction of rotation normal / reverse
o Brake on / off
o Governor mode (helicopter) Additional settings can be made with the separately available V2 programmer (# M318642):
o Cut-off voltage
o Behavior in the event of undervoltage (Cut Off Type)
o Motor timing
o Start-up behavior
o Control behavior (governor mode only)
o Braking behavior (only air mode)
o Number of motor poles
o Gear reduction
o Display RPM max.
o RPM average display
o Write data
o Read data
o Secure data These controllers are equipped with the following protective functions:
o POR: start-up protection, prevents the motor from starting up unintentionally
o PCO: undervoltage shutdown. The motor is switched off in good time when the battery is empty, to reserve enough capacity for the controller.
o hec: high clock frequency (32kHz) for sensitive, magnet-friendly motor control.
o PLC: Super Programming System
o Cool Power FET: New generation of transistors
o RX filter: Switches the controller off if the transmitter signal is missing or invalid. o TP: Thermal overload protection with subsequent power reduction to 70%
o Brake on / off
o Cut-off voltage
o Motor timing
o Start-up behavior
o Gear reduction
o Display RPM max.
o Write data
o Read data
