Robbe 8639-Roxxy BL-Control 900 12S Battery ESC / Vario / Graupner/ T-rex / etc.
FL
Robbe 8639-Roxxy BL-Control 900 12S Battery ESC:
Note:This was never used. I just installed the terminaland installed but Never flown .The manual is clear and simple(Manual included).Original Price $165.00.
Handling and Shipping $6.95 (PayPal or USPS Money Order)
Instructions:
1. Program a gas diagonal (0 to 100%) in the spark.
2. Push pitch stick (gas function) forward
3. Connect Roxxy (Confirmed by short tone sequence)
4. After about 10 sec. a double tone sequence sounds. Here directly move the billet completely downwards (towards itself).
5. This is followed by a short tone sequence followed by a triple tone sequence
6. Disconnect
Roxxy 7. Program throttle straight for governor or V-curve for actuator mode.
8. for the remaining parameters I recommend the Programmer Box!!!
Programming options:
• Model type: Air / Heli, Boot / Car
• Battery type: Lipo, NiCd / NiMh
• Direction of rotation normal / reverse
• Brake on / off
• Governor mode (helicopter) Additional settings can be made with the separately available V2 programmer (# M318642):
• Cut-off voltage
• Behavior in the event of undervoltage (Cut Off Type)
• Motor timing
• Start-up behavior
• Control behavior (governor mode only)
• Braking behavior (only air mode)
• Number of motor poles
• Gear reduction
• Display RPM max.
• RPM average display
• Write data
• Read data
• Secure data These controllers are equipped with the following protective functions:
• POR: start-up protection, prevents the motor from starting up unintentionally
• PCO: undervoltage shutdown. The motor is switched off in good time when the battery is empty, to reserve enough capacity for the controller.
• hec: high clock frequency (32kHz) for sensitive, magnet-friendly motor control.
• PLC: Super Programming System
• Cool Power FET: New generation of transistors
• RX filter: Switches the controller off if the transmitter signal is missing or invalid.
• TP: Thermal overload protection with subsequent power reduction
Instructions:
6. Disconnect
• Brake on / off
• Cut-off voltage
• Motor timing
• Start-up behavior
• Gear reduction
• Display RPM max.
• Write data
• Read data
Spoiler
