Turnigy TR-55 55cc Gas Engine
My Feedback: (16)
WA
This engine is just broken-in with 8-10 flights on it. Never a crash or prop strike.
Specs:
The Turnigy TR-55 engine packs a 5.6HP punch and includes an all machined billet alloy crank, high-power reed valves and porting for high torque! The machined billet aluminum case is strong, and lightweight, that combined with the power it puts out makes the TR-55 perfect for your 50-55CC class 3D and Aerobatic airplanes. Since the TR-55 runs on regular pump gas, operational costs are low, and the fun factor high.
Features:
o Billet aluminum case with sand cast cylinder heads
o CDI electronic ignition
o Includes compact muffler
Specs:
Displacement: 55.64cc
Performance: 5.6hp @ 7500rpm
Idle: 1500rpm
Suggested prop: 22x8, 23x10
Spark Plug: (CM6)
Bore/Stroke: 45 x 35mm
Fuel: 2C Regular Gas mixed 30:1(break-in) - 40:1(Normal flying)
Specs:
Features:
Specs:
Idle: 1500rpm
Spark Plug: (CM6)
