DLE 20cc
My Feedback: (927)
DLE 20cc
DLE 20 engine
Very good condition, upgraded Ignition system from original.
Everything in photo included.
I will include engine mount if I can find it!
$200.00 + $6.00 pp fee
Shipped free in Con US Only
Performance : 2.5HP/9000rpm
Idle Speed : 1750 rmp/min
Static Thrust: 6kg/100 meters Altitude
Static Thrust: 5.3kg/1800 meters Altitude
Recommended Propeller: 16 x8 ; 17×6 ;17x7: 17x8
Spark Plug Type: CM6
Displacement : 20cm3
Diameter × Stroke : 32mm×25mm
Compression Ratio : 10.5:1
Lubrication Ratio : 30:1
Weight of Main Engine : 670g
Weight of Exhaust : 60g
Weight of Ignition : 140g
Ignition voltage: 4.8V-6V
NC
Hi my name is Steve
I’m interested in your dle 20cc what plane did you have it in I have a very nice sig 1/4 scale super cub it looks like it had that type engine unit before whin it was built but it was never flown I was looking at the 30ccdle but I have 2 1/4 j3cubs with Quadra 35 and I could pull the wings off if I wanted with those engines thanks for your time Steve
