Market place question
My Feedback: (88)
AR
I just recently noticed that when I select a category in the market place, and then select one of the tabs under sort that it will not let be go past the first page of listed item without defaulting back to classified.
Example:
I select "Airplanes".
Go to the sort tabs and select "Wanted Ads".
The page refreshes with the items listed under "wanted ads". Here is where the problem starts. If there is more than one page of listed items and I select page 2 or any other page other than page 1, the sort tab will go back to "classified". So there is no way of seeing more than one page of "wanted ad" items.
Is this just a quirk of the market place, or am I missing some setting?
Example:
My Feedback: (325)
RE: Market place question
I tried it and it works fine for me. I selected "airplanes" and then the wanted tab. There were two pages (page 1 was 1-60) and then I clicked page 2 or next symbol and saw page 2 with the remaining wanted add planes (61-87 planes)
My Feedback: (88)
AR
Interesting. After reading your post, I went and check to see if I could do it and it worked like a champ. Well, maybe they changed something because mine hasn't worked for the last month. Thanks for letting me know.
My Feedback: (512)
NC
It isnt working for me anymore either, I cant see past the first page of ads, and have changed the default settings but it still changes when going to the second page.
My Feedback: (325)
I view planes, wanted tab, and had to change my setting to "all" there were only 44 planes so I changed my per page number to 30 and when I clicked on pg 2 it did fine finding planes 31-44.
Perhaps we should report this to JWN because it seems to be an intermittent problem and I sure can't duplicate it , let alone see a fix for it. I will browse more planes in the market though since I am now into planes and NEED some more.
Hmm, JWN sees this thread anyway , no need to report.
My Feedback: (88)
AR
Nope, not a word.. I figured JWN would chime in here some time. Mine worked for the last couple of days, but just checked prior to writing this and is did not work. Who knows!!!
