bad link
My Feedback: (15)
bad link
Not Found
The requested URL /forum/market/listings/engines_motors_turbine_engines was not found on this server.
getting the above notice when i click on the turbine link in the list of classifieds.
edit in
appears that every link under the "classified & auctions" quick link list is giving the same error.
edit in
RETIRED; DO NOT PM
Marketplace had an update. Maybe you were trying to access the links while the update was happening, which is why they might have been down. How are the links working for you now?
RETIRED; DO NOT PM
The marketplace update must have changed the links. You can access Engines & Motors in the new category filter. Once you selected "Engines & Motors" there will be subsections for various engines and motors, including turbines.
My Feedback: (15)
getting better, they are.
now, if ya click on say, turbine engines, in the auctions and classifieds forum listings, it hot links to the general engines/motors category. you then have to manually select the sub category of turbine.
worked the same in a couple of other of the hot links i randomly tried.
RETIRED; DO NOT PM
