Page is too wide Help
Administrator
My Feedback: (12)
RCU should fit every page resolution from 640x480 through 1600x1200 and beyond without any difficulty. However, that doesn't help you, does it?
My guess is you're screen resolution is 640x480 and that is causing the problem. Try adjusting from 640x480 to 800x600 and see if that doesn't help. To make this change, right click in a blank area on your desktop and select settings from the tabs. Then adjust your resolution to the appropriate size.
Hope this helps, but if not feel free to email or private message me. Good luck and enjoy RCU!
