What's battery for MY Rusty VXL
I had sort of asked around a little but I figure who better to ask than a true expert : D I am going to purchase a Rustler VXL this weekend I will need to purchase a battery. I have done much research when it comes to these Li-Po batteries, mainly so that I keep my wife safe and don't burn down the house. I am looking for the best battery for my specific application. I don't really need to go 70 mph to be perfectly honest...so would I be better off with say the 2s2p 6000mah pack or the 3s 5000mah pack? What will yield a longer run time? I know that the 3s will have more punch just due to more voltage...but what will have a longer run time assuming I can't go full bore all the time (from what I have seen this isn't really possible with a VXL anyways, especially with no wheely bar because you can't drive on your lid)?
WA
RE: What's battery for MY Rusty VXL
The 6000 will give you good run around speed and run time. The 5000 will be a bit less but have better power. Also run time will vary on terrain throttle usage and all of that normal stuff. If your not looking for the insane power then go with the 6000's.
Jason
Jason
My Feedback: (325)
Maybe you could get the 3S 5000 and with proper gearing the extra can show up as runtime rather than power/speed. Then when you get the urge for mor speed simply gear higher.
