MaxAmps Support Receive support for your MaxAmps products here!
New to Lipos
Reply
Old 09-08-2007, 08:53 AM
cycleeric
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default New to Lipos
I've got a TC3 converted to Late Model dirt oval running a Traxxas XL10 with a Orion Method 10t. Im wondering what all would I need to switch to Lipo power? I've got a Super Brain 977 charger to do the charging with.
cycleeric is offline
Old 09-08-2007, 09:35 AM
guver
My Feedback: (325)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: New to Lipos
You can use the lipo with your current set-up and should add a LVC (low voltage cut-off) to protect the battery from dischargeing too low. Check Novak, dimesion engineering, ect. for lcv.
Oops, I fogot to mention to size the battery large enough so it will not over discharge amps (current)
guver is offline
Old 09-08-2007, 11:33 AM
JAM MaxAmps
JAM MaxAmps's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cycleeric,
Ask around in the Car forums.....someone there might be running a similar set-up and would be able to tell you what will work and what won't. Really with out knowing how many amps that set-up will pull with the current gearing I can't safely tell you which pack to go with. I don't want you to ruin your equipment or a Li-Po pack.
Jason
JAM MaxAmps is offline
Contact Us Archive Advertising Cookie Policy
