MaxAmps Support Receive support for your MaxAmps products here!
Questions on the Traxxas VXL ESC
Reply
Old 03-06-2008, 03:34 PM
stuball56
stuball56's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Questions on the Traxxas VXL ESC
When using this ESC and MaxAmps 5000 3s Lipo's, I am concerned about the LVC. It is not user configurable as far as I can tell. Do you happen to know the cut off voltages that it uses? And I assume it automaticaly detects whether or not a 3S or 2S Lipo or other battery type is being used? Am I correct in saying that the cut off voltage for a 3S should be 9 volts?
stuball56 is offline
Old 03-06-2008, 03:48 PM
JAM MaxAmps
JAM MaxAmps's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Questions on the Traxxas VXL ESC
Nothing to worry about the LVC point is fine in the VXL systems. Traxxas has used our packs from the start and they continue to be the only packs out there that will get you over 70 MPH. Whether you use a NimH or a 2S or a 3S li-po the system works good.
Jason
JAM MaxAmps is offline
Contact Us Archive Advertising Cookie Policy
