MaxAmps Support Receive support for your MaxAmps products here!
Cold + Lipo = ?
Reply
Old 01-26-2009, 12:55 AM
zaner123
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cold + Lipo = ?
I've been breaking in my new B44 outside in the cold.. between 10 and 25 degrees, and it has a problem of cutting out very frequently.
I am running a Havoc 8.5 with a 21 tooth pinion/84 tooth spur, 2s lipo, Futaba 3pm 2.4ghz radio, w/ deans plugs.
My brother's xxx-4, which uses the same esc/motor and a similar battery, had the same problem a while ago, but it seems to have gone away now.
Can lipo batteries stop functioning properly at cold temperatures?
zaner123 is offline
Old 01-26-2009, 08:43 AM
JAM MaxAmps
JAM MaxAmps's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Cold + Lipo = ?
Yes they loose capacity when cold. Which also means they loose the ability to handle the high amp draw as well. You really shouldn't be running them that cold, you risk damaging the pack.
Jason
JAM MaxAmps is offline
Reply
Display Modes
