MaxAmps Support Receive support for your MaxAmps products here!
Battery Sugestions?
Reply
Old 02-10-2010, 10:13 PM
Wizzard033
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Battery Sugestions?
I have a Multiplex Twin Star II that I have modified with 2 35mm x 30mm x 1250kv Rimfire motors and I want a 4000mah to 5000mah 3s battery thats capable of handleing a total of around 600 watts. What battery would you sugest and what price range would it be in?
Thanks for the help
Wizzard033 is offline
Old 02-10-2010, 10:45 PM
JAM MaxAmps
JAM MaxAmps's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Battery Sugestions?
look at our 3S 5250 here: http://www.maxamps.com/Lipo-5250-111-Pack.htm
JAM MaxAmps is offline
Old 02-10-2010, 11:25 PM
Wizzard033
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very nice!!!
Old 02-11-2010, 12:00 AM
Wizzard033
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also I've noticed that when it's colder the battery I am using is even less responsive. At take-off my current battery was 52deg today and I wasnt able to get many RPM without the voltage of the battery dumping.
Old 02-11-2010, 12:05 AM
JAM MaxAmps
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Li-po's drop capacity and at the same time C rate drops as well. You'll see this change start at 65 degrees and colder.
Reduce run times and how hard you run the packs.
Jason
Old 02-11-2010, 12:09 AM
Wizzard033
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanx so much for all your help. I also noted that i was only able to draw about 30A at this temp. Is it best to keep my batterys at 'room temp' say 75 F until flight time. I fly at a freinds house so this wouldnt be a problem. Also I was considering covering the NACA scoop for the fuse ubntil the temps came back up. Also is the C rate a batteries ability to pass current or only as rating at which it can safely pass a given current?
Old 02-11-2010, 12:21 AM
JAM MaxAmps
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes you can start with a warm pack but more often the pack will cool to much during use. The C rate is just a rating and it's not a very well proven rating system at that. A 5000 20C pack if rated correctly should be able to support 100 amps constant with out pack damage but running a pack at that rate all the time will shorten it's life span. It's like running a NASCAR engine at high RPM's all day during a race. That engine is only good for that day then it's rebuild time. Always try to have more battery than what is needed. A little cushion is always best.
Jason
Old 02-11-2010, 12:24 AM
Wizzard033
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanx for the help I think i'm on the right track and getting a good handle on elctric aircraft.
Contact Us Archive Advertising Cookie Policy
