RCU Forums
-   MaxAmps Support (https://www.rcuniverse.com/forum/maxamps-support-449/)
-   -   HYPERION EOS 0606i AC/DC (https://www.rcuniverse.com/forum/maxamps-support-449/6953194-hyperion-eos-0606i-ac-dc.html)
NJLOAD 01-22-2008 09:32 PM
What balance connector do I need to charge eflite batteries, also need to locate the banana plugs with JST connection. Any one have a good recommendation where to look for these items.
thanks for any help.
JAM MaxAmps 01-24-2008 11:53 AM
RE: HYPERION EOS 0606i AC/DC
E -flight uses the Align taps and the JST leads are here http://www.maxamps.com/products.php?cat=69 and the plugs are here http://www.maxamps.com/4mm-SET.htm use the male side.
Jason
NJLOAD 02-21-2008 07:11 AM
Jason, what is the Data Port used for? I was looking in the Manual and didn't see anything to explain it.
Thanks for any help.
JAM MaxAmps 02-21-2008 07:58 AM
It will be up dateable by computer download in the future. The EOS0610i DUO will be getting the first updates it sounds like there are some minor issues that will be fixxed and then possibly some ne things aded to it.
Jason
gerardbu 10-26-2008 11:36 AM
Question on 0606i
I just got a hyperion eos 0606i ac/dc
I am charging a e-sky 2 cell lipo 7.4 volts 10c discharge rate 800 mha
The hyperion is set to lipo, c=800mha
When I press to charge the unit say balance con connected
and then a few seconds later says no batterry.
I tried also on dc current on a battery and the same result occurred.
I check for continuity between the hx adapater and the wire to plug to the transmitter and tere seem to be no problem there either
I tried 2 new batteries (never used) as well as the current used and all have the same result.
I am able to charge the batteries withthe cheap charger that came with the heli
what am i doing wrong? please if you can help me I would apreciate it.
JAM MaxAmps 10-26-2008 11:53 AM
I answered your post over at RC Groups as well but it appears your making the number one mistake that most new Hyperion Users do. You need to plug in the main battery leads as well at the balance taps. We supply a charge lead with all the Hyperion chargers well sell. That lead plugs into the chargers out put jacks and into your battery main leads. In your case with the smaller e-sky batteries you'll need a JST connector for the leads.
Hope this helps.
Best regards,
Jason
bigireland 11-05-2008 06:50 PM
Hi all,
I recently purchased a MLST2 and a Dynamite 1900mAH 7.4V LiPo battery for it. I have a Hyperion Hyperion EOS 0606i AC/DC coming on order. The charging(balancing?) plug on the Dynamite battery only has 2 wires going to a JST connector. The main discharge connector is of course, a Losi mini connector. I ordered JST adapter for the Hyperion charger thinking that would be all I needed, but looking at everything I'm seeing online is making me have doubts. I've read the instructions for both the charger and the battery and i'm still confused. The battery instructions don't mention balancing at all whereas the charger instructions highly recommend balancing with every charge. Is the "Charge Protection Circuitry" mentioned in the battery instructions some kind of internal balancer? Aren't all balancers a 3 wire deal with 7.4V LiPo? Ok, sorry, my main question is this:will I be able to charge this battery with the Hyperion? I'm just hoping I dont have to order anything else because it takes forever for stuff to get here.
p.s. I posted this question in the Batteries & Chargers section before I found this thread. Sorry for the double post.
JAM MaxAmps 11-05-2008 06:58 PM
Do you have a link to the battery? Sounds like you bought a transmitter pack possibly. There are some makes that have a built in balance protection circut.
Jason
bigireland 11-05-2008 07:04 PM
battery information is [link=http://www.dynamiterc.com/Products/Default.aspx?ProdID=DYN1421]here[/link]
JAM MaxAmps 11-05-2008 07:11 PM
yeah I found the info on it. As I said I would contact them for a clearer explination on how to charge there packs. it sounds as if it is an internal balance circut of some type.
Jason
bigireland 11-05-2008 07:29 PM
yeah i'm gonna have to contact them.. the more i read about how this is supposed to work, the more confused i get.. :(
bigireland 11-05-2008 08:05 PM
just got off the phone with horizon tech support. they said just to go ahead and charge it through the jst lead and not to worry about balancing due to the charge protection circuitry. will the hyperion still charge my battery during a "balancer conn. not connected" situation? thanks again for your time and effort..
JAM MaxAmps 11-05-2008 08:44 PM
It should charge it without the balancer connected.
Jason
bigireland 11-05-2008 10:31 PM
thanks, i appreciate the help..
JAM MaxAmps 11-06-2008 08:37 AM
Your very welcome.
Jason
carnate617 04-03-2009 01:11 PM
ORIGINAL: JAM MaxAmps
Hope this helps.
Best regards,
Jason
Jason,
I am having the same issues as a previous post. On the same charger, I am trying to charge e-flite pack. 2100mAh 3S. When I set the parameters to that, I plug the pack to the JXT connector and press enter. It says Connector is connected, but battery is not. I have tried several working packs to no avail. I assume the banana plugs do not have to be in, and just the JXT box.
Chris
JAM MaxAmps 04-03-2009 01:16 PM
If you read in my previous post. You'll see that the main battery plug and the balance tap both need to be hooked to the charger in order to charge the pack.
Jason
carnate617 04-03-2009 01:45 PM
Jason,
I think i read you right. So, connect the balancer JXT to balance leads on LiPo, and the main pack back to the charger. A loop , if you will.
Chris
JAM MaxAmps 04-03-2009 01:47 PM
http://www.youtube.com/watch?v=fK0ZTUqsukU
Just watch that video I did a while back it should help.
Jason
carnate617 04-03-2009 02:09 PM
Thanks much.
What connectors do you recommend for the main connectors? Deans, the e-flite connectors? just curious.
JAM MaxAmps 04-03-2009 02:22 PM
I use mainly Deans on my planes, heli's and cars up to 1/10th scale. My 1/8th scale cars and my Baja 5B conversion all use 6 mm bullets.
Jason
asterixx25 02-03-2011 05:49 AM
<hr style="color: rgb(255, 255, 255);" size="1"/> <div id="post_message_1126344">My Charger stays in the welcome message Hyperion RC EOS 0606i  AD-B AC/DC and dont do anything, is any way to reset the charger.
Thanks in advance
</div>
