Jet Munt VT80 question
Hello!
The cable that goes from the turbine would i like to extend.
Should I use this http://www.xicoy.com/catalog/product...roducts_id=247
or this http://www.wrenturbines.co.uk/spares...extension-lead
The cable that exiting from the turbine has 4 corde, the cable Xicoy sells only has 3 lead.
What is right?
Excuse for my bad English
Regards
Sejenssen
Norway
What is right?
Regards
Sejenssen
Norway
Hi Sejenssen,
I dont think any of these cables would work. There are 4 wires coming out of the engine, 2 go to the pump and 2 go to the battery, so current goes from battery to turbine and then to fuel pump. I extended all 4 by cutting them and soldering 4 wires in between the cut off parts. Of course you can also do this with only the pump or only the battery wires. Or shorten them. Good luck.
Regard Marco
Regard Marco
