Merlin M90
My Feedback: (21)
Merlin M90
I have a Merlin M90 in a Skymaster 1/6 F-86. After about 60 flights the tailpipe (Tamjet) came apart. The outer pipe came unwelded from the inner pipe. I sent it back to Tam and he said it had been too hot. I have never had a wet or a hot start with this motor. I was wondering if a nozzle was plugeed internally in the motor would that make it run too hot ? It makes good power and runs well. Also, would you please include the link for the owners manual.
Thanks.
Thanks.
RE: Merlin M90
For the turbine manual go to Jets Munt web site:
http://www.jets-munt.com/Merlin90K01.pdf Kero start.
http://www.jets-munt.com/Merlin90Gmk1.pdf Gas start.
For the FADAC manual go to the Xircoy web site.
http://www.espiell.com/FAD06.pdf
Please note not all the features of the FADAC are available with the Merlin 90 as the software has been written specifically for that turbine with the FADAC supplied.
Mike
Mike
My Feedback: (24)
RE: Merlin M90
ORIGINAL: Bobneal1
Thanks.
Thanks.
If the engine is running correctly and the EGT is not excessive I would not be looking at the engine as the culprit. We have seen several tams pipes separate (inner from outer) that was simply inadequate welds. Unless the pipe had signs of internal overheating (blue or purple hazing or wrinkling), I would suspect the problem is a manufacturing defect and not an engine related problem. You can easily see if the engine is burning evenly by viewing the engine while running from the nozzle end (stand back about 15-20ft) and look at the burn pattern, it should be clean an concentric.
