MRC Charger Product Support (i.e. Super Brain, etc) Tim Sandor of MRC/Hirobo is your host. Ask all your MRC questions here!
Help with Superbrain 989
Reply
Old 12-15-2014, 02:34 PM
akm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Help with Superbrain 989
I have a MRC SuperBrain 989 and when charging lipos it will charge until the voltage is 4.2v per cell then stop charging. The charger just stops and does not continue onto the CV mode.
akm is offline
Old 12-15-2014, 05:48 PM
collector1231
Moderator
collector1231's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
First, make sure you're doing a balance charge. Second, it may just do that. My Dynamite Passport Ultra does that on some charges. If the charger is broken or at fault, the Venom PRO2 LiPO charger is the right way to go.
http://www.atomikrc.com/collections/...attery-charger
collector1231 is offline
Old 12-16-2014, 05:41 AM
John@MRC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello AKM,
The 989 should switch into the CV mode after the CC mode has completed. When the CC mode is finished the 989 will beep and display the word "Trickle". The charger is not actually performing a trickle charge on the battery. This is the indicator that the CV mode has begun. When the full charge has completed, you will see the word "END" appear where the amperage is displayed. You may also consider the battery fully charged when the amp display reads 0.00.
Collector1231 is correct. A balancer should be used while charging a lipo battery. We sell one that you can purchase directly from us or through your local hobby shop called the Accutec Balancer and can be found here:
http://www.modelrectifier.com/search...w.asp?ID=11403
If you have any further questions feel free to ask or contact me at chargersupport@modelrectifier.com
John@MRC
John@MRC is offline
Old 12-16-2014, 03:34 PM
akm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the unsolicited sales pitch and a post that has nothing to do with the issue I am having. And no thanks on venom products. I will contact John at MRC for further help but I will post the results of our correspondence so the info may help someone else that may be experiencing the same issue.
akm is offline
Contact Us Archive Advertising Cookie Policy
