960 charging 4200 EP packs
KS
I have a Superbrain 960 and just bought a 7 cell EP 4200mAh hump pack.
What should the peak threshold be set at, or should I just hit the start button and let the Brain decide it?
Also it falsed peak the first time I charged it. So I hit the start again and it charged for another 20 mins then peak again. The cells were 95 to 98 degrees F. I guess this is normal for new cells for the first couple of times charging them?
NJ
RE: 960 charging 4200 EP packs
I would charge it at 4 amps and 35 mv. The charger should pick the appropriate peak setting, I would just change the charge rate to 4. After the first charge you can then charge it at 4.5 amps.
