If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2002
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    989 questions
    I just got 1 of these and have a few questions. I will be using this charger for flight packs and 12vdc sla hobby batteries.
    1) The green jack on the side is where you make all your connections for charging/discharging? (I know it sounds stupid but their manual is useless)
    2) I assume I'll have to modify the output connector/connectors so I can charge NiMh/NiCd packs as this connector is not compatible with banana jack leads which most accept.
    3) Does someone make any adaptors for the banana jacks for this charger?
    I have a Triton I have been using and like it but needed another charger and thought I'd try something different.
    Thanks in advance,
    Dave
    Fly Fast, Fly Hard, Die Happy!
    It's only bad if you can't fix it!
  2. #2
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 989 questions
    You are correct , didn't it come with 1 or 2 leads anyways? It should have.
    I made mine like this so I can use the green or bananas. http://www.rcuniverse.com/forum/fb.asp?m=9218203 The only thing I'd change would be to line up the red and black jacks with the + and - labels that are already on the charger. I'm not aware of any pre-made adapters.
    and airplanes were in
  3. #3
    Join Date
    Jul 2002
    Blaine, MN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 989 questions
    ORIGINAL: guver
    I made mine like this so I can use the green or bananas. http://www.rcuniverse.com/forum/fb.asp?m=9218203*The only thing I'd change would be to line up the red and black jacks with the + and - labels that are already on the charger. I'm not aware of any pre-made adapters.
    I took the charger apart and the green output jack is soldered directly to the printed circuit board. How are you guys making the connection internally using female bananas?
  4. #4
    Join Date
    Mar 2003
    LaGrange, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 989 questions
    I soldered to that same point and ran two short wires to my jacks.
  5. #5
    bigedmustafa's Avatar
    Join Date
    Jun 2005
    Omaha, NE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 989 questions
    I simply use the alligator clips that came with my Super Brain 989 to clip to the male banana connector leads on all of my charging adapters. I put a piece of foam rubber between the leads to prevent them from touching while cycling or charging. I'm not charging anything faster than 2200mAh, so this has worked fine for me.
    When everybody is out to get you, paranoia is just good thinking!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
