FAA Registration...Is it a Requirement
This question is for those that are in the know; Is the FAA registration for drones, mandatory, or optional? Reason that I'm asking, is that I've recently gotten into the drone fpv hobby and I've seen quite a few articles on having to register, to not having to register! Who can point me into the right direction?
If you fly something not attached with wires/strings (anything, not just "drones"), and it weighs more than .55 lbs, you must be registered. Start here: https://www.faa.gov/uas/recreational_fliers/
Note that you are registering yourself, not the craft - you would put the same registration number on each of your aircraft.
Most (but not all) clubs and the A.M.A. generally take the stance that they are not in charge of policing the rule. A few do, though, demand proof of registration to join. So generally whether you will go to prison for life if you don't register mostly depends on what official law enforcement you have a run in with.
It's not prison for life! LOL
Yes, its a requirement. The penalty is a fine up to 20,000 so for a 5 dollar registration its a relative bargain.
As to the yes and no thing, registration was enacted by an FAA rule that violated a federal law but they interpreted that it didn't, a court case was brought that affirmed they did indeed violate the law and threw out the registration requirement, so in the next FAA funding bill the FAA got it written into law and again requires it.
Its cheap, its easy, and its the law so there's no reason not to do it. Use the link tedsander posted, if you Google it you will come up with any number of paid services that offer to register you but charge you 5x as much.
The link does not take me to the actual registration process; am I missing something?
Yes, if anything that you fly is over ~1/2lb, you have to be registered. On the FAA link I noted above, read Step 1, which contains a link in the text to start the registration process.
In the FAA’s eyes, any remotely piloted vehicle is a “drone”. And in those pages, they seem to think a person would only have one, so it implies you have to register each - but deeper in the process, you find that you only need to register once for all your aircraft. The AMA has been trying to get them to accept the AMA number as a valid registration number, but no firm result yet. So at this time you need to have both on your plane. Several of my fellow club members protest this by printing very small stickers with micro-print, and putting the FAA number in the hinge line of their plane!
IMO, problem is AMA doesn't have the legal teams and technical staff these organizations have to have their standards adopted. Basically,
Originally Posted by Wizard of ID, May 3, 1965
Whoever has the gold makes the rules.
Banned
My Feedback: (49)
What is the current up to date FAA requirements
I have been at best semi active in RC for the last few years but am getting much more active and plan to continue to. I do have an FAA registration and have my number displayed on most of my models (have a couple new ones that have not yet been flown and have not had the numbers put on them).
I am told or under the impression that the requirements have expanded or changed.
Where do I find a complete and comprehensive list of all FAA registration requirements ?
If you go to the link I posted above, under "New Changes..." is a link to the law that was passed in 2018, (all 400+ pages of it!). For the average model flyer, the information on the main page above (and subsequent pages) should suffice.
The current topics of the day, that come from the passage of that law, and FAA actions:
1. Central administration of permission to fly in controlled airspace near airports. Rather than clubs getting permission from the airport, it will all come from the FAA itself.
2. In uncontrolled airspace, the FAA is generally saying the altitude limit is 400 ft.
3. The AMA is providing a list to the FAA of all affiliated club flying fields.
4. In the law is authorization to require a test to get the registration number. The FAA is still figuring out what the test should be and how it is to be administered.
5. In the law is a provision allowing the requirement to have, essentially, transponders in all unmanned aircraft. No action on that being required, yet. But it is authorized, if the FAA ever wants to implement.
One other thing to remember is that as recreational pilots, we can now use LAANC (Low Altitude Authorization and Notification Capability) to get authorization to fly in some controlled airspace.
The FAA's "dronezone" website is one place to go, but smart-phone/tablet apps like KittyHawk and Airmap. The FAA's B4UFly app doesn't allow you to submit an authorization request, but it does give a quick check on airspace.
LAANC was a huge boon to me because one of my favorite flying areas was right at the edge of the local airport's class-C airspace. Until August I could only fly there using my Part 107 certificate. Now I can go a "fly for fun" and not have to worry about logging time or the other miscellany Part 107 requires/encourages.
