Multi Rotor Helicopters Discuss Multi rotor RC Helicopter's here!
Blade 350 QX Binding --- Help
Reply
Old 09-29-2013, 07:41 AM
BalsaBob
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Blade 350 QX Binding --- Help
I have tried (for hours) to bind my 350 QX to a DX5. It is a new DX5 (with the 3 position switch) that they sent me separately (the sent me the 350 QX BNF instead of the RTF ... so they sent me a transmitter separately). I've tried everything .... and still get the fast beeps.
Also, how do I know what to set the channel switches to ... REV or NORMAL .... for each channel ?
Thanks. Bob
BalsaBob is offline
Old 09-29-2013, 11:03 AM
Cdntrini
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Bob, this is a very advance bird I suggest you read the instructions a few times top to bottom. Not the whole book, just the first few pages about the Modes and binding. How exactly are you trying to bind them, step by step?
Regards, Mario.
Cdntrini is offline
Old 09-30-2013, 06:21 AM
BalsaBob
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, I did it step by step .... and I keep getting the fast beeping tone.
Bob
BalsaBob is offline
Old 12-29-2013, 07:51 AM
Brettis1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try the thread in RC groups theres quite some interest. I have a DX8 and it did everything as per book.Although I didn't read manual, I did troll through scores of youtube vids. I only picked mine up yesterday so no expert yet.
Brettis1 is offline
Old 12-29-2013, 08:54 AM
randall1959
randall1959's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make sure all your switches are up or it won't bind. To bind, turn on the 350QX, wait for the blue flashing light, then turn on your DX5e with the trainer switch pulled back and hold it until you get the green light indicating that the 350QX is bound to the tx.
randall1959 is offline
Old 01-03-2014, 07:18 PM
pequeajim
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob:
I don't know if you received an answer to your question or not, but I had the same problem with my 350QX and couldn't figure it out. As it turns out, you MUST have all your trims set to neutral before it will bind. This is what the fast beeping is. Also, if you are inside, try switching out of GPS mode. I finally set my DX7s trims to neutral and bingo, the quad bound. I hope this helps.
pequeajim is offline
Old 01-12-2014, 08:29 AM
macawman3542
My Feedback: (155)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Blade 350QX
Hello, I have two of these and both crashed in flight. The first on hovered and then crashed in the road about 6 feet above the ground. The ebay seller let me send it back for a new one or refund. The second one did the same thing yours did. I ended up taking it apart and found esc to motor squashed between the upper and lower parts. I am sure the first one had the same problem with wires squashed between the upper and lower haves. I also found three other wires from the main board, esc's and leds I am going to call horizon and see if this is a common problem with builds at the factory. They should be notified of this. Two out of two is pretty bad in my opinion.
Patrick(Mike)
macawman3542 is offline
Old 01-16-2014, 06:53 PM
marter1229
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't abandon the thread, let us know!
Terry
marter1229 is offline
Contact Us Archive Advertising Cookie Policy
