Newbie Building X copter, help with KK Board
I finally got all the components to build my first quadcopter and need help flashing the controller board. I bought a KK v5.5 with the USBasp programmer. It came loaded for a + configuration and I need to change it to the X config. I went to kkmulticopter.com and it looks like that site is no longer available.
What program and firmware do I need to flash the board and where can I get it? Thanks in advance. |
RE: Newbie Building X copter, help with KK Board
Go to lazy zero for software. The instructions are on Hobbyking website under files. You can use the HK V2 controller for the site info, just be sure you select your board when you flash and the config you want quad X or Quad +
One other thing is you will have to load drivers for your programmer interface.
ORIGINAL: tlrascal Go to lazy zero for software. The instructions are on Hobbyking website under files. You can use the HK V2 controller for the site info, just be sure you select your board when you flash and the config you want quad X or Quad + |
