Trouble With ESCs
1 Attachment(s)
Hi. I'm extremely new to forum posting and quad building, but I started a build with the help of someone who had done it before. I am using the Spektrum F400 Raceflight Flight Controller. I have attached the receiver, which is also Spektrum, and have bounded it to the controller. In Raceflight I get feedback from the controller so I know the receiver is bound correctly. My issue is that the ECSs will not react to the controller, or the Raceflight motor tab. Even when I try to arm them nothing happens. I was wondering if this could possibly be because the F400 flight controller is not compatible with the ESCs. The list provided by Attachment 2216753 shows the Lumenier 35A BLHeli_S to be compatible. The ECSs I am trying to use are Lumenier 30A BLHeli. My worry is that the 30A and lack of _S are making the difference here. If this is not the issue, let me know and I will post a picture of the wiring and full parts list so someone can check behind me. Also, let me know if this is the right place to post this on the website :) Thank you.
