MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Broken LED lead on Ignition Module
Old 12-07-2010, 06:38 PM
gsmith6879
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Broken LED lead on Ignition Module
Hi,
I have an MVVS 26 gasser with the MSR ignition module. This is one of the earlier units that has the LED leads sealed in the unit. My newer units have a plug in lead. One of the lead wires has broken at the sealed area. Is there any way to reconnect the lead. I assume I would have to cut some of the "potting" material away to get to the solder area but don't know how.
Any ideas?
gsmith6879 is offline
Old 12-08-2010, 08:37 AM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Broken LED lead on Ignition Module
yes, remove some of the potting material to get to the printed CB.
Then take care that the lead out is fixed, so no loads can reach the soldered joint.
BTW, this should be done with all leads coming out of the device.
pe reivers is offline
Old 12-08-2010, 09:20 AM
gsmith6879
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: pe reivers
Very good! I will dig the potting material out and repair. Can I use the epoxy glue that we use for modeling to re-pot the repaired wire and the other leads coming out of the unit?
Old 12-08-2010, 03:21 PM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
use hotmelt. That will do fine.
Old 12-08-2010, 04:31 PM
gsmith6879
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pe,
Thanks very much.
Gaines
Old 12-25-2010, 02:53 PM
gsmith6879
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Made the repair this week and your directions worked perfectly. Thanks again.
Old 12-26-2010, 08:16 AM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All's well that ends well.
With best season's greetings,
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
