MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
Prop for MVVS 40cc
Old 09-28-2011, 10:02 AM
styk
Default Prop for MVVS 40cc
Hi
can i ask your advice on what would be a good prop for a MVVS 40 flying a 9kg 80" span P51 Mustang. Its fitted with a wrapround inverted pitts muffler. I was thinking about a 20x10 what do you think??
Best Regards
Styk
Old 09-28-2011, 10:43 AM
pe reivers
Default RE: Prop for MVVS 40cc
I think that would be a good choice. The pitts may be restrictive, so don't expect rpm in excess of 7000. (Jtec pitts power is about the same as MVVS muffler #3271)
Old 09-29-2011, 12:12 AM
styk
Thanks very much for the advice Pe. Much appreciated
Best Regards
Styk
Old 10-02-2011, 01:40 AM
pe reivers
good luck with your 'Stang project.
