If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 4 of 4
  1. #1
    Join Date
    Oct 2002
    Springfield, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    MVVS 40 power
    What sort of RPM could I expect from a typical MVVS 40 using 0% or 5 % nitro, the 3248 mini pipe and an APC 10x6 prop? I have an upcoming project that I think the MVVS 40 would be suitable for, but I am not sure what power I could expect from it.
  2. #2
    Join Date
    Jan 2002
    Arcen, , NETHERLANDS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: MVVS 40 power
    expect about 13,000 rpm. A well tuned header length maybe a bit more.
    Pe, (www.mvvs.nl), MVVS, MOKImotor, RCexl, MTW, Xoar, Mejzlik.
    Blessing in ignorance? There is sanctuary in analysis.
  3. #3
    Join Date
    Dec 2001
    Upplands Vasby, SWEDEN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: MVVS 40 power
    Hi!
    If you change the rear ball bearing to a WIB C4 bearing, removed the head shim, Used a Nova Rossi 4 or 4A glow plug, you could expect around 14000-15000 rpm using the MVVS 3248 mini pipe.
    The standard MVVS .40 engine turns a 10x6 APC at around 13200-13600 rpm on FAI (80/20) fuel.
    Best 10x6 prop is either a RAM or Graupner "Cam-prop", not an APC!
    Jan Karlsson - Supplier MVVS Products
  4. #4
    Join Date
    Jan 2002
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: MVVS 40 power
    My suggestions are always a bit pessimistic. Better to err low than to create disappointments.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
