MVVS 35cc ICU - L magnetic sensor wire damage?
Ive managed to damage the magnet sensor lead on my MVVS 35cc ICU - L by allowing it come into contact with the hot exhaust (yep, stupid I know). It still works OK but will require repair sooner or later. The wire leads directly into the black box which does not appear to be simple to open, presumably I can repair the wire by cutting out the heat damaged section and rejoining ie soldering, heat shrink, and a little more care!.
Thanks in advance,
Bob V
Thanks in advance,
Bob V
RE: MVVS 35cc ICU - L magnetic sensor wire damage?
Meesh ........
Thanks for that, is the wire 3 core or two core? anything special required?
Bob
