mvvs .77 12x11 11500 Rpm ????
Hello All ,
Top model french mvvs importer in France claims the Mvvs .77 can swing a prop 12x11 - 11500 rpm
http://www.topmodel.fr/product-detai...77-gfsr-abc-rc
I am really doubtful on this as most of the therad speaks about 10300 for a 13x8 which is less torque than a 12x11
Would those 11500 rpm with a reso pipe available with a 12x11 ?
Thanks for your comments
Ger56
Ger56
RE: mvvs .77 12x11 11500 Rpm ????
I need to be fast , but also some torque
My idea would be to install it on a Sig King Kobra
12X11 _ 11500 rpm would give 112 mph
The Mvvs is more low rpm high torque ...
Ger56
Ger56
122 mph , theorical yes but my software include drag and other parameters ....
nevertheless the purpose of the thread is to know if the Mvvs 77 can get 11500 on the ground at 0 level with a max temp of 20° C
Regards
Ger56
Regards
Ger56
Theory not only but it depends of the plane your use Drag on the fuselage , wings , retracts , weight , weather , How much the engine is unloading in the air .....
Ger56
Ger56
Pe ,
As I am sure you know very well the Mvvs engine , so could you just tell me If I can get the 11500 rpm with a 12X11 .
I believe your advise should be enough for me .
Regards
Ger56
Regards
Ger56
I honestly do not know. I never tested it myself. If MVVS states they achieved those rpm, who am I to doubt it. But since all engines and mufflers are not alike, your engine may run differently. MVVS probably used the long tuned pipe (item 3250) to get these rpm.
Thank you for your answer Pe ,
May I ask on which engine and plane you did get 122 mph with a 12X11 running 11500 rpm checked by a radar ?
Regards
Ger56
Regards
Ger56
Regards
Ger56
Regards
Ger56
You said : Not theory alone. Results frequently checked by radar gun measurement.
As you seem to have made a lot of test , I wanted the engine and plane you used .....
Regards
Ger56
Regards
Ger56
I do not need any proof , I juts want to understand and know the plane and weight as this may change a lot the speed .
If you know Mvvs engine , it should have been very easy to just answer to my question on post #2
Now if you want to keep secret your test planes , there is no reason to be on a forum !
Regards
Ger56
Regards
Ger56
