MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS 2.5D RRV
Reply
Old 08-01-2012, 06:38 PM
fiery
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default MVVS 2.5D RRV
Hello Pe
I would be grateful if you could answer some questions about this engine:
1. Will the piston and liner set for recent production MVVS 2.5 diesels fit OK in this engine?
2. Is a factory header available?
3. If so, does the usual pipe for the 2.5 engine will fit up to it, with the supplied silicone coupling tube?
ID:	1788189   Click image for larger version
fiery is online now
Old 10-09-2012, 07:44 PM
fiery
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: MVVS 2.5D RRV
I located a piston and liner for a current spec 2.5D. They fit the above engine perfectly.
Porting and timing in the new liner is a little different. I ended up leaving in the old liner. It must not be overly worn as the new piston makes a nice gas seal using it.
The old conrod was unbushed. Both little and big ends were worn. The current spec conrod (supplied fitted to the piston in th enew P&L set) is sturdier, and bronze bushed on the big end.
All fitted up with no issues, except I made a thicker back plate gasket to stop the crank pin binding on the disc valve. Valve clearance is good, no scores on the mating faces.
It's looking good.
fiery is online now
Contact Us Archive Advertising Cookie Policy
