MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
26GT2 ignition battery
Old 12-15-2007, 08:20 AM
duber3
duber3's Avatar
Default 26GT2 ignition battery
HI!
I have a twin engine plane, and I plan to put 2 Evo 26GT2, if Iput only one battery for the ignition , how many mAh I will need, for my evo58GT2, I have a lipo 7.4 1500mAh
I suppose a lipo 7.4 3000mAh will enought??
thanks!
Old 12-15-2007, 09:35 AM
DarZeelon
DarZeelon's Avatar
Default RE: 26GT2 ignition battery
Duber,
A single 3,000 Li-Po will power both engines' ignition systems, like a 1,500 Li-Po will power that of one engine...
I suppose a 'single point of failure' in a remotely operated plane may not be as great a disadvantage, as it is on a piloted plane.
A plane flown by a pilot is usually capable of 'limping home', if one engine fails...
But an R/C plane is, for most pilots, easier to bring home for a 'dead stick' landing (even a very remote one) than it is to be controlled with one engine out...
SPOF is usually a disadvantage in other circumstances.
Old 12-15-2007, 01:36 PM
pe reivers
Current draw for each ignition at top rpm of 6500 is about 650 mA.
With the single 1500 mAh battery you so have about one hour flight time in your twin engine plane.
Old 12-15-2007, 10:53 PM
duber3
duber3's Avatar
thanks for the anwsers!!
